1991 Carver 26 Command Bridge: Shower sump pump location
- c44588
- Vessel Info: 1991 Carver 26 Command Bridge
JBC/Seattle
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: 1991 Carver 26 Command Bridge: Shower sump pump location
Do you have a breaker on your electrical panel marked shower pump or something similar?
- Has thanked: 603 times
- c44588
I have owned the boat the entire time and have never used the shower sump pump. It has a dedicated shower pump switch on the electrical panel. I have removed the floorboard panels inside the cabin and also looked in the engine room for the shower pump, all to no avail. The shower itself is a 'uni-body' plastic shell construction, so I dont know how you get to the sump pump if its located in such close proximity to the drain itself without cutting into the shell. I would guess it would be located at or below the surface of the sump flooring...
Any other ideas? I guess I may have to pour some water down the drain and hope for the telltale humming to locate it....
Appreciate the help greatly! Jack
- c44588
- c44588
I am sure you don't have to cut the shell of the shower surround to get access to the pump. There would be very little clearance under the shower... probably just enough for the drain and right angle fitting for the hose to attach.
On the floorboards inside the cabin that you removed... did they give access to the center of the bilge? That area between the closest stringers would be the lowest place and best place to put the sump. (and that's where my fwd sump was on my boat). Did you locate the through-hull discharge where the water should be coming out? Perhaps by the process of elimination you can determine which one it is, then follow THAT hose back to the source.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
there is a pump in the engine room that you need to switch on. Switch under the window next to the wash basin. Drain tube from shower to the engine room to the pump and there directly overboard.
It has a different overboard discharge then the wash basin so perhaps that's causing confusion: no exit directly next to the shower afaik.
Good looking boat! looks original, would like to see more pics. Inside (electrics, layout, fittings) too!
Users browsing this forum: No registered users and 56 guests
