Electrical switch
Wayne162
"Change In Latitude"
Has thanked: 16 times
Been thanked: 32 times
Electrical switch
Postby Wayne162 » November 25th, 2015, 3:11 pm
The attached photos are of what appears to be a dimmer switch in the master state room of my 1997 Carver 405. It does not work and I don't know what it's for. Can anybody tell me what it does?
After Taxes
Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada
Has thanked: 6 times
Been thanked: 17 times
Re: Electrical switch
Postby After Taxes » November 25th, 2015, 4:08 pm
Could it be a remote volume for the stereo?
MerCruiser MX 6.2
Lake Simcoe, Ontario
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Postby AaHubb » November 25th, 2015, 5:11 pm
The technical term is an L-pad. It acts as a volume control for remote speakers while maintaining a constant load to the stereo.
..Aaron
'99 404 CPMY
SeaDragon
Wayne162
Postby Wayne162 » November 27th, 2015, 8:49 am
Ahh, maybe that is why the interior stereo speakers are not functioning. I will give it a look and see if that is the problem. Thank you.
Has thanked: 64 times
Been thanked: 481 times
Electrical switch
Postby waybomb » November 28th, 2015, 1:38 pm
AaHubb wrote:Source of the post The technical term is an L-pad. It acts as a volume control for remote speakers while maintaining a constant load to the stereo.
..Aaron
Can you tell me the "why" one would want a constant load to the amp? Does a built in fader in the head unit do the same thing, meaning, allows for a constant amp load?
AaHubb
Electrical switch
Postby AaHubb » November 29th, 2015, 10:47 am
Yea, my bad. "Load" isn't really the right term. I should have said impedance. An L-pad maintains the impedance (8 ohms) to the amp while varying the signal to the speakers.
..Aaron
'99 404 CPMY
SeaDragon
Wayne162
Electrical switch
Postby Wayne162 » November 30th, 2015, 12:04 pm
Thanks all. It appears to be an L-pad.
Electrical switch
Postby waybomb » November 30th, 2015, 1:18 pm
AaHubb wrote:Source of the post Yea, my bad. "Load" isn't really the right term. I should have said impedance. An L-pad maintains the impedance (8 ohms) to the amp while varying the signal to the speakers.
..Aaron
Thanks for answering - now I know!
Return to “Electrical”
