Another Boating Season Done
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
Re: Another Boating Season Done
Who knows. I will call to make an appointment to look her over if not sold yet. I don't know if the link will work but here she is:
https://www.temptationyachtsales.com/bo ... n-7542650/
2022 Stingray 182 SC
- Has thanked: 468 times
- Been thanked: 1765 times
- Has thanked: 598 times
- Been thanked: 1281 times
Actually the keel is not totally hollow depending on the day at the factory.......the resin was fairly thick from the bottom ( if too much there was too much heat), but there is a hollow section under the roving in the center under the steps area, easily dealt with and may have been already, you will see if so........
- RGrew176
- Been thanked: 1180 times
- Has thanked: 78 times
- Been thanked: 1093 times
- Been thanked: 601 times
I think it is on facebook market place for 26k, but I know you could get it for 20, maybe a bit less.
km1125 wrote:Source of the post I thought it was interesting that the Trojan had FOUR fuel tanks (or at least that what it looked like). Looked like FOUR fuel gauges and four separate leads going into the two filters. I liked the fuel manifold, as it looked like you could run either engine from any one of the four tanks, but I would have added two more filters and moved the two present ones to before the selector valves, so that when you switch to a different tank you're also switching to a new filter.
They brought that back as My 41CMY has 4 tanks. Can select either port or starboard tanks and transfer fuel from to each on the mains however the aux tanks cannot be transferred between each other.
Click on photo to see larger view, 4 fuel gauges.
- RGrew176
tomschauer wrote:Source of the post Hey Rick, I know of a trojan f-34 for sale in my marina. the guy that owns it now only had it for two years. The previous owner had it for several years and is a good friend. It has rebuilt engines (crusaders 5.7) with low hours and runs great. Has genny and a/c. No windless.
Just out of curiosity where is this boat located?
Users browsing this forum: No registered users and 9 guests
