Window weather stripping (Cat Whisker) replacement
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » September 6th, 2021, 8:21 pm
I contacted Taylor Made and no longer stocking the weather stripping for my 94 390CPMY. They sent me samples that I could try and match up. However, no matter how many times I look at these windows, I can’t figure out how to get them out of the tracks to replace the weather stripping. From outside? Inside? Suggestions?
Thanks!
Tony
Been thanked: 1111 times
Re: Window weather stripping (Cat Whisker) replacement
Postby km1125 » September 6th, 2021, 9:13 pm
If they're the snap-in type, I just grabbed an end with some needle nose pliers and pulled the old stuff out.
Liechtenstein
chpsk8
Has thanked: 27 times
Been thanked: 76 times
Postby chpsk8 » September 8th, 2021, 8:01 am
It’s called zipper pile weatherstripping. You can measure the features and match it up pretty easily. To remove it you pull it from one end and it will come out. It is probably sticky getting out due to age, I know mine was a pita to get out. The windows don’t need to be removed, you can just slide it past the windows in place. It isn’t super easy, but it isn’t too hard either.
tonyiiiafl
Postby tonyiiiafl » September 8th, 2021, 9:05 am
Thank you, I am onto trying this this weekend. Where di you lol get yours?
Postby g36 » September 8th, 2021, 11:10 am
Could thus be of help? I used this onmy 405.. dkhardware.com CRL Z78295C Zipper Pile Weatherstrip .270" Backing - .250" Pile Height - 100' Roll
tonyiiiafl
Postby tonyiiiafl » September 8th, 2021, 8:33 pm
Thanks G! I ordered. WAY less than Amazon too!
Netherlands
Phrancus
Has thanked: 16 times
Been thanked: 136 times
Postby Phrancus » September 9th, 2021, 12:51 am
Mine were completely worn or hard like cement with dust, algae and crud.
With picks (like dentists use, with a hook at the end) I managed to scrape and pull it all out. Then with brushes got another bucket of dust out.
When you do that, you'll discover small drain holes. Obviously, as from now I'll flush those at the end of the season before storage (we don't shrink wrap here) and start of the season.
tonyiiiafl
Postby tonyiiiafl » September 9th, 2021, 2:59 am
Mine is also fossilized like that in the tracks. Hoping it will stop some leaks when it rains.
Postby km1125 » October 27th, 2021, 2:26 pm
Ran across some pictures that I had taken when I replaced the pile weatherstripping on the windows on my 3607.
tonyiiiafl
Postby tonyiiiafl » October 27th, 2021, 3:16 pm
How did you get the entire track done? Did you do 1/2 then slide the window back and do the other half? And the fixed panel? Thanks this will make it easier for us!
