12 Years in water at Marina
- LovaCarver
- Vessel Info: Carver 3207 Aft Cabin
Re: 12 Years in water at Marina
Bud37 had asked...."do the engines have heat exchangers, do they have antifreeze as a coolant or raw water in the engine blocks ?"
I'm attaching a screenshot. Being a newbie when it comes to these things, I'm not sure if this is some form of heat exchanger or...
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
FYI, when looking at boats, you need to know if the engine is raw water cooled (RWC) or fresh water cooled (FWC). RWC uses sea water only to cool the engine. FWC is like a car engine with anti freeze running through the block and possibly, exhaust manifolds. Instead of an air cooled radiator that cars have, you have a heat exchanger where sea water cools the engine coolant. A full system has the exhaust manifolds included in the closed cooling system. A 1/2 system does not include the manifolds. Risers/elbows are always raw water cooled.
Obviously, FWC engines are much preferred over RWC engines, Especially when boating in salt or brackish water.
- LovaCarver
So, can a RAW system and a FWC system both utilize a heat exchanger? How might I know which this boat has? The owner is a shipwright/cabinet maker. Not mechanically knowledgeable.
- buster53
FWC is just like a car engine with antifreeze/coolant circulating in a closed loop, transferring engine heat through the heat exchanger.
I have to say, the picture you have does look a little odd.
- mrterry72@gmail.com
- Vessel Info: Carver 2006 35ss
- Has thanked: 2 times
- Has thanked: 598 times
- Been thanked: 1281 times
LovaCarver wrote:Source of the post Thanks again for all the feedback. I think I've made my decision NOT to go forward with this "opportunity".
I believe you have made the right decision here, given your place in the learning curve .......Odd as it may seem, sometimes the most costly to repair are the free ones especially if you have to pay someone to do the repairs/upgrades.
Good luck with your further hunting........that is always the fun part for some........
- LovaCarver
- buster53
- LovaCarver
buster53 wrote:Source of the post Buying boats to fix up and flip for profit rarely happens. Pretty much the only people who can do this are seasoned boaters who are way up the ladder in boat repair-maintenance knowledge.
10-4 !
