REMOVAL OF RADAR ARCH -CARVER 320
BillyBob Babnick
Vessel Info: 2002 Carver 380 Santego SE
Twin 8.1 Merc HO's.
Has thanked: 11 times
Re: REMOVAL OF RADAR ARCH -CARVER 320
Postby BillyBob Babnick » December 9th, 2021, 12:54 pm
waybomb wrote:Source of the post You guys don't know how heavy the thing is. Get a forktruck, gantry crane, boom truck, something, but do not attempt to manhandle it. Once it's loose, it's loose. Don't hurt yourself. And not only are they heavy, they are awkward to move.
Yeah, that's why I'm going to rent one of these material lifts ( https://www.homedepot.com/p/rental/Sumn ... /309450521 ) to support it while me and my buddy disconnect each side. Then we can lower it an secure it for transport inside the cabin.
Postby km1125 » December 9th, 2021, 5:32 pm
I'd be surprised if you could get it inside the cabin. Usually they're strapped down on the bow of the aft deck.
BillyBob Babnick
Twin 8.1 Merc HO's.
Postby BillyBob Babnick » December 15th, 2021, 4:03 pm
Update.
No issues using the material lift taking that arch off.
Got it to this point, then flipped it, restrapped it and adjusted the lift and guided her on down and secured for for transport.
BillyBob Babnick
Twin 8.1 Merc HO's.
Postby BillyBob Babnick » December 15th, 2021, 4:15 pm
I will say, now that I have the boat down on Texoma, I wet launched her off the transport trailer and pull the boat over to the marina and helped the two guys running their lift reinstall the arch. Much easier. Didn't take 20 minutes.
I had them pull it out of the water because I'm having a vinyl wrap kit coming in that I'm gonna put on it.
Noticed the impeller was a little loose and had two small dings in it.... ( I'm pretty sure I did it driving it up onto the transport trailer because I took his tail light off)... :banghead:
So now I need to figure out either replacement or sending it to Houston for a refurbish job... :up: :down:
Postby km1125 » December 15th, 2021, 5:44 pm
Great job! Thanks for the update!
Could you estimate how heavy it was when you were moving it around?
BillyBob Babnick
Twin 8.1 Merc HO's.
Postby BillyBob Babnick » December 16th, 2021, 1:57 pm
km1125 wrote:Source of the post Great job! Thanks for the update!
We left the speakers on so it had some added weight. If I had to guess, I'd say between 350-400lbs with the speakers.
wrachilla
Postby wrachilla » September 14th, 2022, 1:15 pm
How did this all turn out? What did you use and do you have any tips? I'm about to do the same thing...
