I've either made a horrible decision or a great investment
- Has thanked: 58 times
- Been thanked: 457 times
572s=900hp each at 5800 rpm. 1.5 reduction. 33" cleavers. 18,000 pounds wet.
Topic author - Scurvy Dog
- Vessel Info: 2000 350 Mariner
Twin Mercruiser 5.7l Horizon
Garmin 4212 - Location: Space Coast Florida
- Been thanked: 21 times
- CaptBob
- Vessel Info: Shopping....
- Been thanked: 33 times
More Nautiville 2004 Carver 360 Sport Sedan
A little less Nauti 2008 SeaDoo 150 Speedster (Admiral could not live without a jet boat....
Nautiville 2005 Cruisers 280 CXi *Sold*
Nautitown 2012 SeaDoo 180 SP *Sold*
Ouch.
There's always a bright side though.
SO MUCH ROOM FOR ACTIVITIES!!!
While the motors are at the machine shop I'll be cleaning the bilge, pulling the fuel tank, prop and propshaft as well as doing some cable/hose management. I heard back from the prop shop yesterday and both the shaft and prop were pretty bent. He said the run out on the shaft was .16". At this point with both prop shafts out I'm going to change the cutlass bearings as well. I noticed on the survey it noted that they were approaching the end of their life. The goal here is to do EVERYTHING that would require a haul out now while its out.
I got tired of lifting the generator hatch on and off and decided to pull the FireBoy off to make it lighter. I'm sure it wouldn't have been much longer before I would be cleaning that out of the engine room
- Has thanked: 461 times
- Been thanked: 1721 times
Took the second motor to my rebuilder today. The head with the broken valve is toast. At this point he suggested I pick up a couple rebuilt engines from one of his suppliers. We crunched some numbers and it just makes more sense.
Does anyone know where I would find a battery charger or inverter for this thing? There's a charger under the bed for the battery connected to the bow thruster but that's all I have found so far.
- Vessel Info: 1986 carver Santa Cruze
- Has thanked: 3 times
- RGrew176
- Has thanked: 72 times
- Been thanked: 468 times
2022 Stingray 182 SC
