Fuel tank level sender question
KnotSure
- Vessel Info: 1996 Carver 455
Eden Isle, La
- Has thanked: 78 times
- Been thanked: 1093 times
Re: Fuel tank level sender question
Are you saying you looked up from the bottom (where the tank is) and you don't see any access hatches?
I would also just wiggle the wires at the sender to see if it might be a corrosion issue. There should be a sensor wire and a ground, so check them both. I had that problem on one of my tanks and I eventually replaced the ring connector which solved the issue. Also, do you have a toggle switch for the gauges, or separate gauges for each tank? If a switch, you might check the connections there too.
KnotSure
Eden Isle, La
- Has thanked: 469 times
- Been thanked: 1765 times
- buster53
- Has thanked: 10 times
- Been thanked: 284 times
- Been thanked: 646 times
KnotSure
Eden Isle, La
