Noflex Digester VS Sodium Percarbonate
Been thanked: 1180 times
Postby Midnightsun » January 11th, 2022, 8:05 am
Have been using Noflex Digester for a few years now and must admit it works very well for not only controlling holding tank odours but also cleaning the tank and lines. Only drawback is it is rather spendy and difficult to find however ordering on the web has simplified things except for those delivery costs which add even more to the product. https://marinesan.com/noflex-digestor/
Been comparing and reading quite a bit since haul out last fall. Just do some searching for sodium percarbonate and noflex. The active ingredient is Noflex is 80% sodium percarbonate which is an oxidizing agent. Have come across multiple post claiming percarbonate works the same as Noflex however before I say it does I will need a trial season on the water. Probably will work better as I wont be so skimpy on using it any more. ;-) Here are a few links discussing the subject. Read between the lines, use your own judgement. ;-)
https://www.trawlerforum.com/forums/s31 ... 51219.html
https://www.trawlerforum.com/forums/s31 ... 46357.html
Ordered a 5 gallon pail (40lbs) of the stuff on ebay for $100 delivered to a US address. Advertised as 99% pure. This is a huge savings, about 10x less as those Noflex bottles are only 1lb of product at about $30 each. May even try diluting it with baking soda to the tune of 20%. Got enough product for the rest of my life I believe. :-D https://www.ebay.com/itm/174910196252
Has thanked: 598 times
Been thanked: 1281 times
Re: Noflex Digester VS Sodium Percarbonate
Postby bud37 » January 11th, 2022, 5:57 pm
That is a fair bit if product there.....wow.....a question.....due to the contents, will they ship in Canada without documents. I am guessing you know that material is hygroscopic so storage will be an issue, but you could do your laundry/clean the bilge etc for quite some time......good stuff.... :-D
Postby Midnightsun » January 11th, 2022, 7:03 pm
They do not ship to Canada but there is always a solution. Put the product in a watertight pail today. Have a few of these at the shop which seal very well and are easy to open/close as required. Use the same pails for aquarium salt and can store for years without issue. https://www.usplastic.com/catalog/item. ... emid=24495
Been thanked: 646 times
Postby g36 » January 12th, 2022, 8:38 am
im sure the problem must be shipping to canada on the noflex. cause in the states i can get 5 bottles for $78.76 and no shipping or tax from marine sanitation still some spendy but this last us quite a while seems like, 3 years. so really no big deal. it is still cheaper by weight in the pail you bought on ebay if it does the same ,im hoping you may have found a option to save, please post what when you know.
Postby Midnightsun » January 12th, 2022, 9:37 am
I figure at least 4 bottle of Noflex/season. You are supposed to use quite a bit if you follow the instructions that is. I purchased a case of 12 back in June 2020, have 4 bottles left and use it very sparingly, not like they recommended otherwise I would probably only have 1 left. :help:
Noflex instructions. https://www.boatersmate.com/noflex-dige ... structions
Marine Sanitation is the link I have in the original post. Todays price for 5 with free shipping is $105 US however this is in the US. That would be for 5 lbs
Ordered mine from Jetvac however after shipping and taxes it came to $329 or $27.40 CDN per bottle. Probably gone up since then though. That would be for 12 lbs of the stuff. https://www.jetvac.ca/
Postby g36 » January 12th, 2022, 11:27 am
The difference here is the candian and usa difference.when I pull ip the Canadian website I see your pricing. . using the usa website where I live is this. when I posted the earlier link I ordered 5 at $78.76. If you add it to the cart it changes it to 2 different line items and the price changes/ discount. I am happy with how it's been working for me and maybe it's not used as heavily as the recommended dose. We use 2 or maybe 3 bottles a season. My wife handles this and I know we have used this for at least 8 years now. I'm not trying to make any deal with this and again it's cheaper in bulk if it's the same outcome.. so best of luck.
From their website
"Applied After Adding Noflex To Your Cart.
( purchase 4 or more to take advantage of the largest discount or 5 to get FREE SHIPPING!"
Noflex Digestor
4 x Noflex Digestor
$64.80
Noflex Digestor
1 x Noflex Digestor
$13.96
Postby Midnightsun » January 12th, 2022, 1:11 pm
Good old exchange rate confusing things. ;-)
Postby bud37 » January 12th, 2022, 4:52 pm
Yup...exchange + shipping + border fees usually make it around double the original price. Up here we have to be very careful, it is quite the minefield...... :help:
Carpediem
Vessel Info: In process of buying 2000 506 with Volvo TAMD 74s
Has thanked: 2 times
Been thanked: 25 times
Postby Carpediem » January 12th, 2022, 11:14 pm
Over on the Club Sea Ray site there has been a long standing thread about this. Look up Carter's Poopy powder. Mix 2 parts Sodium Percarbonate with one par sodium carbonate and you have No Flex digester equivalent. I bought 1 10 lb bag of Sodium Percarbonate and 1 5 lb bag of Sodium Carbonate (Soda Ash) so I have 15 lbs of product for $59 delivered from Amazon. I still had three bottle of No Flex so have not had a chance to mix and use the DIY version but will be feeling better about using more of it than I do the No Flex.
Carpe Diem
Try to only boat where ducks don't walk
Postby Midnightsun » January 13th, 2022, 1:01 am
Thanks for the tip. Only thing I see different there is they are using a different ratio. The MSDS say it has 80% percarbonate which is a 4/1 ratio. May not make that much of a difference though. Going to pick up some soda ash at Amazon.ca. This should work for me, after mixing I now have 50lbs :-D https://www.amazon.ca/gp/product/B07RQHD6PX/ref=sw_img_1?smid=&psc=1
