Battery charger only charging Genet battery?
- Dark Horse
- Vessel Info: "Dragonfly"
2001 Carver 350 Mariner
Twin 350 MAG MPI - Location: Hudson, FL
- Has thanked: 1 time
- Been thanked: 6 times
Recently the engines would not turn over so I replaced both the main batteries. When I went back to the boat 2 weeks later, those batteries were almost dead. The boat is in a wet slip with dual 30 amp power.
So i checked the battery charger and it appears it's only charging the Genset battery. The charger is a Mastervolt 12/3-40. I can check each bank and it shows that the main battery is low. (Shows a series of light bars and while the genset battery shows 3 yellow bars which is good, the main batteries show 1 red bar not so good)
Is it possible that the charger has failed?
I checked all the wiring and nothing loose or corroded. Checked with a volt meter and it seems like its only putting out a reduced voltage (7 volts or less). Maybe swap wires from genset to main and see what it does?
I am thinking I will have to replace the charger as I am not sure how to further test and / or fix this issue.
Any ideas?
2001 350 Mariner w/ 350 Mercruisers
Home Port - Hudson, FL
Re: Battery charger only charging Genet battery?
- Dark Horse
As a TEST, you can also swap the connections on the charger end and see if the problem (low volts) changes when you move the generator connection over to where one of the starting batteries is hooked up. CAUTION - realize that those cables are connected to the battery (via previously mentioned fuse or breaker) so those ends will be "live" and need to be protected from shorting as you removed and replace them.
- Dark Horse
- Has thanked: 603 times
Dark Horse wrote:Source of the post I have not as I didn't know there would be any inline fuses. Not sure where to look for those but will check tomorrow when I go to the boat.
If your boat is still wired as factory then the charger 12v side goes thru breakers in the panel where your battery switch is.......aft corner wall of salon above the couch....they are labeled. Become familiar with that panel and the relationships with the battery 1, 2 ALL positions as that will portion out the battery reserve to the boat when you are away from the boat.....even with that switch turned to off the charger will charge whatever batteries you have told it to with the breaker switches.
That 7 volts is probably the dead battery reading. Check out what you have before you decide the charger is no good.
The 120v breaker for the charger is in the panel below the entertainment center......hopefully no previous owners have messed with this......
- Dark Horse
To test the voltage i took both ends of one of the drained batterys and put the voltage meter to it and thats where I ready 7 v. I am guessing the 7v was coming from the charger as I had battery switch off so it was isolated from other battery.
I have an idea that charger has been changed as I believe based on our boat and a few friends the factory charger was a Charles 5000 series, but my old memory could be wrong....
Disconnect the leads at the batteries themselves and take your readings there.....FYI...be careful with that wiring bundle behind that panel as I am sure you found out, it is real tight and it is easy to break switch/breaker terminals.
- Dark Horse
And to measure the charger voltage I do just that. I disconnect both positive and negative cables from one battery, turned master switch to off so I got no back feed voltage from other battery and measured. It read 7.3 volts. I belive it should be 14 v according to owners manual.
Both battery bank 1 and 3 (main batterys) are showing low battery while the generator battery is just fine.
