Unleaded fuel 1984 PCM 351 engines
- Justright
- Vessel Info: New owner of 1984 Riviera 2807, purchased October 2021. Pre-purchase survey found the boat to be very solid structurally and mechanically. The electronics were expensive when new (1994) but are now dated. The original instruments work, except for the engine synchronizer. The twin Pleasurecraft Marine 351W Ford engines and Velvet Drives are in top shape. The boat is in storage for the winter. In Spring 2022, I will update the electronics, install a larger swim platform and begin making cosmetic improvements, such as refinishing all the teak brightwork, and I might replace the analog gauges, etc. Now we have the winter to decide on a name! She will be moored at Bayview marine in Portland, ON.
- Has thanked: 4 times
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Unleaded fuel 1984 PCM 351 engines
- Has thanked: 603 times
Now in the early to mid 70's most engine manufacturers changed cylinder head design to include hardened valve seats because of the new EPA rules to go to unleaded fuel. So my guess, your engine being just a factory crate from 83 or so has the seats so all is well.
Now I can tell you that even engines with the so called soft seats ran for years on unleaded with little or no recession that would have required the heads to be rebuilt and hardened seats added .......a non issue.
So, I am pretty sure those engines have not seen much, if any leaded fuel.
- Justright
tomschauer wrote:Source of the post I am really surprised a 1984 engine is labeled as requiring leaded fuel. Unleaded was started in the mid-seventies in the US and leaded was pretty much phased out by the mid-eighties I do believe.
I appreciate all the replies to my question. It's comforting to know. I was surprised too. I might have a photo of the label and send it.
