Transducer
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 487 times
Been thanked: 206 times
Transducer
Postby pepmyster » January 31st, 2022, 3:50 pm
I'm in the middle of choosing my transducer for our vessel. We have a Garmin 1242xsv touch. My main question is all about installing a transom mount transducer. This transducer will do clear view, side view, depth and temp. Anyone here ever install a transom mount transducer on this style boat? Thanks.2004 360 Sports Sedan.
Been thanked: 601 times
Re: Transducer
Postby tomschauer » January 31st, 2022, 7:25 pm
A transom mount transducer won't work very well on a boat with inboard engines. The transducer needs to be in front of the props or you will only see clutter on the display due to prop wash, air bubbles etc. Unless you are at or near idle speed.
pepmyster
8.1 Volvo Penta
Fresh water boating
Re: Transducer
Postby pepmyster » February 1st, 2022, 5:51 am
So, There's no real spot to install a transom ducer?
Has thanked: 469 times
Been thanked: 1765 times
Re: Transducer
Postby Viper » February 1st, 2022, 9:43 am
Not a good idea for your application. You've spent good money for the display, don't diminish the system's capabilities by skimping on the wrong ducer for your application. Transom mounts are fine for outboards and sterndrives but not the best choice for inboard vessels.
pepmyster
8.1 Volvo Penta
Fresh water boating
Re: Transducer
Postby pepmyster » February 1st, 2022, 1:55 pm
So looks like I have to do thru-hull?
pepmyster
8.1 Volvo Penta
Fresh water boating
Re: Transducer
Postby pepmyster » February 1st, 2022, 7:01 pm
After talking with Garmin, I'm going to go with traditional sonar. In hull transducer with the angle rings to get the best position.
https://www.garmin.com/en-US/p/530269
I guess I really wanted to get clearvu but the only way to get it is thru-hull.
Re: Transducer
Postby tomschauer » February 1st, 2022, 7:18 pm
What's one more hole in the bottom of the boat?
Re: Transducer
Postby Viper » February 1st, 2022, 11:53 pm
Personally I'd be drilling a hole. It's not that big a deal to do.
pepmyster
8.1 Volvo Penta
Fresh water boating
Re: Transducer
Postby pepmyster » February 2nd, 2022, 5:56 am
The thru hull transducers are way out of my budget plans.... :cry:
PhotoHog
Vessel Info: 2003 Carver 444 Extended Salon (purchased late 2021)
Cummins 370s
Freshwater - for now.
Been thanked: 3 times
Re: Transducer
Postby PhotoHog » April 5th, 2023, 1:41 pm
Did you end up installing the in hull transducer? How's it working?
Users browsing this forum: No registered users and 1 guest
