Carver 3607/3807 measurements
- MdeVries
- Vessel Info: Carver 3007 refit 2x Yanmar 4tn100 75hp
- Has thanked: 3 times
I am looking to buy a 3607/3807 model and arrange transport for it. I love the model and would be a great upgrade to my current 3007. The dimensions for transport are pretty critical however. I am looking for the height measurement as if the flybridge was removed. Is there an owner that can help me with finding these dimensions? I would be immensely grateful.
Cheer,
Michiel
Re: Carver 3607/3807 measurements
EDIT - I just noticed the flag in your profile, and it doesn't look like you're from the USA. Sorry, my mistake but maybe there's someone who has some email contacts at various shippers here who might be able to forward that as a lead.
- denders
- Vessel Info: 1985 Carver 3607 Aft Cabin
- Has thanked: 2 times
- Been thanked: 24 times
- MdeVries
Thanks again for your information, this is much valued.
- denders
Taking off the rudders and props, you'll reduce that by a little bit, but not much as the boat also had a nearly full keel. You might gain another 6-8". That would correspond closely to denders numbers, especially considering they still needed some ground clearance for the trailer.
If you did remove the bridge, I think you'd gain close to 1M. You'd have to remove the bridge surround (not real hard, but awkward), the aft seating (easy) and then the fiberglass helm structure. That means disconnecting all the helm wires (most all have OEM plugs for that purpose, but any owner-installed stuff would have to be cut or removed), the control cables for throttle and shift, and the hoses for the upper station steering.
Do you have to allow for a cradle or trailer or something else to support the boat?
My 355 is a bit over 41' LOA and I believe 13'3" beam.
Thier 36 is definitely bigger than my 355.
The 3607 definitely had less beam though then a 355/356, and I know that 12'6" is right on the money.
- denders
