raw water pump system
- ontariojeff
- Vessel Info: 2003 Carver 570
- Has thanked: 2 times
I have been reading helpful information from this site for years.
Figured it was time to join.
I have a list of questions but for now I will try to stay focused on my main issues.
Seems my raw water motor for my closed circuit heating/cooling may be seized. I have purchased a 1/3 hp replacement.
It was a nightmare removing the old one, I have taken off the four bolts holding the electric motor to the pump.
Now the damn motor will not separate from the pump system no matter how hard I try.
Thinking the drive shaft may be screwed or somehow attached to the pump?
Also the power to the motor on the electrical panel tests with no voltage? Think I may have blown a fuse, there are no breakers tripped on the inside galley panel.
Thanks.
Re: raw water pump system
- ontariojeff
Here is a pic of what I'm dealing with.
Note the yellow screwdriver in the small crack where it will not seperate.
- Has thanked: 603 times
What is the name on the assembly ?
Have a close look to see if there is a clip under that corrosion inside that area next to the screw driver.
What's the shaft look like on the NEW motor?
If that's the kind that has a mechanical seal then perhaps the shaft goes all the way though to the impeller, with a nut on the end, like this:
- ontariojeff
The new pump shaft looks like this...
- Has thanked: 474 times
Good luck and keep us posted.
- ontariojeff
Just some replacement 1/2 in hose and I will have A/C (and heat) again!
Thanks all.
Users browsing this forum: Google [Bot] and 31 guests
