New zinc placement on 1976 Mariner 2896
- Ctmangrum
- Vessel Info: 1977 Carver Mariner 2896
- Has thanked: 37 times
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: New zinc placement on 1976 Mariner 2896
FYI, you should have been using magnesium anodes when in fresh water.
- Ctmangrum
- buster53
As far as how many anodes you should have, it really depends on the application and conditions. Some will have just a transom anode, or transom and shaft anodes, and some will have transom, shaft, rudder, and tab anodes even though they may not be needed. The only way to be sure is to take readings at your slip. Having said that, readings will change when you go to another port. When considering anodes, you also want to ensure your bonding system is intact and that connections are clean and tight.
