1976 Mariner 2876 trim tabs
Ctmangrum
- Vessel Info: 1977 Carver Mariner 2896
- Has thanked: 37 times
- Has thanked: 469 times
- Been thanked: 1765 times
Re: 1976 Mariner 2876 trim tabs
- Cooler
- Has thanked: 68 times
- Been thanked: 406 times
Ctmangrum
Viper wrote:Source of the post Typically they're on their own circuit independent of the engine and other systems, so nothing else has to be turned on for them to operate. I assume they're hydraulic, when you operate the control, can you hear the pump running? Have you checked the fluid level? What brand is it? Bennett, Instatrim Boat Leveler, Teleflex?
Bennet hydraulic an I didn't hear the pump but, i was also by myself in a working boat yard so it would be hard for me to hear from the flybridge. Ill get someone to stand by the bilge and listen. If there's no pump sound, what are you thinking? Ive done no troubleshooting yet.
- Has thanked: 78 times
- Been thanked: 1093 times
- Cooler
Ctmangrum
Cooler wrote:Source of the post If you are in a boat yard, I assume you mean the boat is on blocks, on the hard. Check to see if the batteries are disconnected. Lot of yards require you to disconnect the batteries while the vessel is in storage status. Are the blowers working?er
Its on the hard and i have power. Im currently "sprucing up" the boat.
Ctmangrum
Ctmangrum wrote:Source of the postViper wrote:Source of the post
They worked with just the battery switch on. I was just testing with the wrong circuit tester and was not showing any power. (110v instead of 12v). Rookie mistake.
