Carver 444 Stern Thruster Picture
Cooldogz
Re: Carver 444 Stern Thruster Picture
Postby Cooldogz » February 27th, 2022, 2:49 pm
I don’t know if you have all you need since this is over one month old, but here are some 444 pics installed. Sidepower. If I had to do it over, I would upgrade to the ignition protected version. The lazarette stay pretty wet and it has caused a lot of rusting on the Internal parts. Apparently this is solved with the ignition protected version.
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Postby Tireless » February 27th, 2022, 3:45 pm
Interesting location for the thruster. I assume that it is not in the water while on plane. This location means less fibreglass work and could be a DYI due to the flat mounting service.
Could you advise if there is resistance on the thruster while on plane? I assume that if there was it could pull away from the mounting.
Could you explain this following comment to me and would the rust still be an issue with a fresh water application?
“The lazarette stay pretty wet and it has caused a lot of rusting on the Internal parts. Apparently this is solved with the ignition protected version.”
Greg
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » February 27th, 2022, 9:55 pm
Tireless wrote:Source of the post.....Could you explain this following comment to me and would the rust still be an issue with a fresh water application?
Greg
It's really going to depend on the conditions in your bilge back there Greg. it wouldn't be much different than a bow thruster install. If you ever get any water in that area, the components will rust even in a fresh water app. The ignition proof unit comes with a sealed housing encasing the entire unit. The housing consists of two halves bolted together that can be taken apart to service the thruster.
PhotoHog
Vessel Info: 2003 Carver 444 Extended Salon (purchased late 2021)
Cummins 370s
Freshwater - for now.
Been thanked: 3 times
Postby PhotoHog » April 21st, 2022, 10:10 am
I am having a SideShifter rear thruster installed on my new to me 444 next week.
I will post photos when it is done.
