Kohler 10eozd Generator Under Voltage Code
Rocketman
Vessel Info: 2009 44 Sojourn w/ Volvo Diesel D6-500 engines and IPS drive system.
Been thanked: 22 times
Postby Rocketman » March 1st, 2022, 7:58 am
Kohler 10eozd diesel gen set is setting under voltage code when first cranked and shutting down.
If I keep trying to crank, it will eventually (after maybe 5 or so times) run and operate fine.
Seems to be a bad (corroded) connection or something.
Any suggestions on where to look or what to look for would be appreciated.
The manual is not much help on this code other than call for service.
Has thanked: 598 times
Been thanked: 1281 times
Re: Kohler 10eozd Generator Under Voltage Code
Postby bud37 » March 1st, 2022, 8:43 am
Heh there.....clean your positive and negative generator battery connections, also the generator ground strap if you have one. ensure the generator battery is full charged, then check the battery voltage with a DVM while cranking with the generator engine......that should tell you if the battery voltage is dropping too far during the load from cranking.....
It may simply be the battery is giving up......but checking before deciding is wise in this case.
Rocketman
Postby Rocketman » March 1st, 2022, 12:09 pm
The generator is cranking fine.
It is sensing an under voltage on the A/C output and shutting down after 10 seconds.
I don't think it is the battery since it cranks just fine. I will verify though.
Will check the grounding strap as well.
Been thanked: 601 times
Postby tomschauer » March 1st, 2022, 12:12 pm
There is a good chance it is the capacitor. They are cheap and easy to change so I would start there.
Rocketman
Postby Rocketman » March 1st, 2022, 1:09 pm
Can you give me more info on the capacitor.
Where would it be located and any idea of a part number?
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » March 1st, 2022, 1:32 pm
So it actually does START and then shut down? That wasn't clear in your first post. If that's the case, then I agree with Tom... probably a capacitor issue and it's getting weak and will eventually be too out-of-spec to produce any power.
Rocketman
Postby Rocketman » March 2nd, 2022, 7:16 am
Did some more work yesterday. After removing and reinserting all the connections on the controller it seems to be working fine. I am hoping it was just oxidation on the connections not allowing good contact for the sensors.
Will see.
Return to “Electrical”
