Sideshifter Thruster
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Add to the cables with same size. Total will be about 12’ run
add heavier cables to the original cables, so two different sized cables.
Cut original cables back to where they come through the hull and use O sized cables?
This is a 24V system using 2 12V 900CCA batteries set up in series.
Suggestions?
Tony
- Been thanked: 654 times
Re: Sideshifter Thruster
- tonyiiiafl
- tonyiiiafl
Users browsing this forum: Matriarch and 45 guests
