Port engine stalls while running after a while
- Ctmangrum
- Vessel Info: 1977 Carver Mariner 2896
- Has thanked: 37 times
I have twin Ford 351's in a 1976 Carver Mariner 2896
- Ctmangrum
Re: Port engine stalls while running after a while
Are you running it hard when this happens? (high 3000's or over 4000' rpms?) If so may be getting hot, you can't always trust gauges especially on an older boat.
Fuel filters and tank pick up screen. Again, does this happen when running hard? tanks can have "junk" that will clog the inlet screen when drawing a lot of fuel. When you shut it down for a bit, it will fall off the screen and you can run again.
I would look into the fuel filters and the fuel system first.
- Ctmangrum
Do you have one or two tanks?
If this is a new to you boat, could be bad gas and water in the tank also.
- Ctmangrum
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
Ctmangrum wrote:Source of the post I just changed the fuel/water separators a week ago.
problem occured after that?
- Steve2020
- Vessel Info: 2006 41 CMY
- Has thanked: 21 times
- Been thanked: 4 times
