Phrancus wrote:Ctmangrum wrote:Source of the post I just changed the fuel/water separators a week ago.
problem occured after that?
Yes. Ill probably change the fuel water separators again just to eliminate that as the cause.
Ctmangrum wrote:Source of the postPhrancus wrote:Ctmangrum wrote:Source of the post I just changed the fuel/water separators a week ago.
Steve2020 wrote:Could be plugged tank vent line. Quick check is when engine stops open fuel cap to release negative pressure then try to restart engine, spiders love to plug vents. Happened to me twice.
Ctmangrum wrote:.... nor do I have an anti-siphon that I see, but I also didn't check all the way behind the engine. ....
Ctmangrum wrote:I ran it in the slip at different RPMs for quite a while and never had any issue. I guess only time will tell. ...
Ctmangrum wrote:Source of the post... Does the V Dr. have an actual audible alarm if it overheats? Not just the warning light on the dash? Would Cut to cut off? Just curious
Users browsing this forum: Carverlvr2 and 29 guests
