1995 Carver 325 aft cabin not getting on plane.
- rbutler1959
- Vessel Info: 1995 Carver 325, Twin 350 Crusaders
- Has thanked: 2 times
- Has thanked: 602 times
- Been thanked: 1310 times
Re: 1995 Carver 325 aft cabin not getting on plane.
How long did the boat sit in the water after the bottom job, you are in salt I'm guessing here. Recently rebuilt carbs, was wide open throttle checked, are they opening all the way....somethings to check.....good luck with your purchase.
- rbutler1959
That boat should top out at over 30mph with a clean bottom and good running engines.
BTW, revving in neutral doesn't tell you anything, and is not good for engines if done for more than a second or two.
Good luck!
- Been thanked: 654 times
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
How many hours are on the engines? Are they both performing exactly the same?
- Been thanked: 1111 times
- buster53
buster53 wrote:Source of the post I would think that boat should be able to get on plane at 3000 RPM’s, certainly more than 11 knots.
Generally true, the tipping point seems to be around that rpm so long as the engines are making enough HP to push the boat on top. We will have to wait and see the result of rbutler's investigations regarding the carbs/boat bottom/tuning condition etc. Oddly enough here the boat should have been pulled for the survey, then the bottom and props would have been documented. His explanation of the engines bogging and just pushing water is telling, we will see. I know on some carbs the power piston will do this, and the secondary lockout tab will stop the secondaries opening until the engine is warm, that tab needs to be adjusted so it works correctly all the time with the choke heater.
