OVERHEAD LED COCKPIT / BRIDGE ROUND LIGHT REPLACEMENT
DAA76
Vessel Info: 2016 CARVER C40
Postby DAA76 » May 18th, 2022, 11:44 am
I HAVE A 2016 CARVER C40 AND WOULD LIKE TO REPLACE MY OVERHEAD LED COCKPIT LIGHTS. CAN ANYONE TELL ME THE BRAND CARVER USED ? I REMOVED ONE OF THE LIGHTS BUT I COULD NOT FIND A BRAND NAME OR SERIAL#. THANK YOU DAVID
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 284 times
Re: OVERHEAD LED COCKPIT / BRIDGE ROUND LIGHT REPLACEMENT
Postby buster53 » May 18th, 2022, 1:09 pm
Quick question...why are you replacing? Only 5-6 years old, so they should still be in good shape. Are you replacing with the same?
DAA76
Postby DAA76 » May 18th, 2022, 2:01 pm
I am looking to change to Blue lighting if possible. 2 of 4 cockpit courtesy lights started to dim so I replaced them with blue lighting.
buster53
Postby buster53 » May 18th, 2022, 2:16 pm
DAA76 wrote:I am looking to change to Blue lighting if possible. 2 of 4 cockpit courtesy lights started to dim so I replaced them with blue lighting.
Are you replacing the fixture or just the bulb?
Been thanked: 601 times
Postby tomschauer » May 18th, 2022, 2:55 pm
Blue light looks cool but brings in bugs from miles away it seems. I installed blue lights for one season, and then went back to white.
At least with the white you can see what you are doing.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 406 times
Postby Cooler » May 18th, 2022, 7:10 pm
You may want to consider checking your area regulations. Blue lights in some areas are restricted to law enforcement vessels only. Sitting at the dock should not be an issue, but lights on while running could draw some unwanted attention. 8-) er
Cooler By The Lake
Return to “Electrical”
