Hot Water Tank
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Hot Water Tank
- PaulH
- Vessel Info: 1997 Carver 355 Motor Yacht, with two Mercruiser 7.4 L, MPI inboard engines.
- Has thanked: 5 times
Re: Hot Water Tank
How could I confirm the hot water tanks heat exchanger is the problem?
- Been thanked: 1111 times
Re: Hot Water Tank
PaulH wrote:Source of the post I believe that I might have a similar problem. I have checked all of the onboard water connections (hot and cold) and don’t find any leaks, but my pressure water pump continues to come on every three or four minutes to restore the pressure. This happens most frequently when the hot water heater is turned on. I think that there is a crack in the hot water heat exchanger and water pressure is being lost by water escaping through the cracked heat exchanger into the raw water cooled engine. The hot water tank is 25 years old, so there could be corrosion cracking or possibly the winterization wasn’t sufficient.
The heat exchanger is easy enough to test. Just pull the hoses off (coming from the engine) and loop them together so you can still run the engines. Then, you can either leave the heat exchanger ports open and see if any water starts leaking out, or you can put a "jumper" hose across them to seal the system. If the potable water stops its periodic pumping then you've found the cause.. if not, then continue looking. Could just be some debris in the valves of the pump too that's causing some leak-back when it's not running. For that, you can disassemble, clean and reassemble.
- PaulH
Re: Hot Water Tank
Re: Hot Water Tank
PaulH wrote:Source of the post I believe I have a leak through the heat exchanger. When the hot water tank is connected to the freshwater system the pressure pump keeps coming on every few minutes to top up the pressure. When I isolate the hot water tank from the fresh water system the pressure pump works correctly. The hot water tank heat exchanger is directly connected to the raw water cooling for the engine, so no water is coming into the inside of the boat!
Did you see the previous post?
Do you have freshwater or rawwater cooled engines?
