Crusader 270 falling on its face
- ataylor233
- Has thanked: 83 times
- Been thanked: 7 times
.. port engine runs great Starbord engine when underway after 3k rpm seems to spudder and drop the rpm to around 2500. when this happens i pull thr trottle down a bit then i can push it back up to 3k rpm.... i set both engines to 10 degrees btdc could this be a fuel issue i've added an additional fuel filter to both engines over the stock.This engine also has a new carb purchased last year. not sure if it needs to be tuned or cleaned .. this is annoying ... any advice or am i missing something?
- Has thanked: 603 times
Re: Crusader 270 falling on its face
Is the fuel pump electric or mechanical ?
- ataylor233
bud37 wrote:Source of the post What brand carb is on that engine and was it brand new when installed. A new one should be fine, always check the float height before installing/with new gaskets etc. You shouldn't need two fuel filters for each, perhaps a restriction there.
Mechanical fuel pumps fuel water separators are in addition to the stock filters on the back of the engine.
- Been thanked: 654 times
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Sounds like a typical fuel restriction. Could be plugged filters somewhere, or an anti-siphon filter that needs to be cleaned or replaced. Could also be a plugged vent on the tank on that side.
- ataylor233
A restriction prior to the fuel pump is going to cause the pump to need to work harder to deliver more fuel when you need it under load and higher RPMs). A new pump might "fix" the issue, only because it's a little more capable than an older and worn one, but isn't really resolving the actual problem.
Did you ever absolve the anti-siphon valves? They are frequently an issue when fuel delivery becomes a problem.
