Safety Equipment Check
Postby Midnightsun » May 25th, 2022, 7:45 pm
Have neglected this as we do not use these items unless all hell breaks loose. Kinda like that spare tire in your car which is probably at 4 psi if your lucky enough to have an older car that still has a spare that is. :confused:
Checked the dates on my flares and saw they expired in 2019. :-( I know they are still functional however one needs to abide by the expiry dates if verified and there is a minute chance a couple will not work. Just a friendly reminder. :captain2:
pepmyster
8.1 Volvo Penta
Fresh water boating
Has thanked: 492 times
Been thanked: 210 times
Re: Safety Equipment Check
Postby pepmyster » May 26th, 2022, 5:59 am
Very good reminder. I'm sure mine, now that you said it, are most probably expired as well.
Been thanked: 1310 times
Postby bud37 » May 26th, 2022, 8:38 am
There is also a fine for out of date flares if you are on water checked by the CG or the OPP........much higher in the USA.
Fire extinguishers is another item they will check.....there are some changes to the regs around 38-39 feet so be careful here as well.
Postby Midnightsun » May 26th, 2022, 9:18 am
Here are the requirements for Canada, maybe someone can list the US requirements?
https://tc.canada.ca/sites/default/file ... p_511e.pdf
40' and over gets rather weird as I need the normal stuff but it goes from 6 flares to 12 and then an axe? and at least 2 buckets capable of holding at least 10 litres. Really scratching my head on the Axe thing.
AaHubb
Vessel Info: '99 404 CPMY
my twin diesel pusher
Has thanked: 15 times
Been thanked: 61 times
Postby AaHubb » May 26th, 2022, 10:14 am
I've forgone the flares completely in favor of a battery powered beacon and a day emergency flag. A fresh set of batteries each spring and I'm good for the year. Its been accepted in the US for several years now but I don't know about Canada.
..Aaron
'99 404 CPMY
SeaDragon
Postby Midnightsun » May 26th, 2022, 10:30 am
Canada does not accept electronic flares because we are still in the ice age here when it comes to boating requirements. I do have one as a personal choice however according to transport Canada it is useless. There is a bunch of stuff you guys in the states can use be we cannot.
Been thanked: 1111 times
Postby km1125 » May 26th, 2022, 11:03 am
I still think it's absurd that in over 50 years we can't certify flares for more than 3 years at a time. That's no guarantee they'll work either, within that window. If they're not properly cared for they might not work months after manufacture but if you store them well they could easily last 10 years.
Postby Midnightsun » May 26th, 2022, 11:20 am
OMG, Canada has got you beat. In the US your flares are good for 42 months, Canada is 48 months. :-D
Netherlands
Phrancus
Has thanked: 16 times
Been thanked: 136 times
Postby Phrancus » May 26th, 2022, 3:06 pm
you don't have to replace all do you? just add a fresh one and each year you fire off the oldest at new years eve...
Postby bud37 » May 26th, 2022, 3:59 pm
Flares are cheap, in any on water emergency you could have only a very few minutes at most to react so having fresh flares is a must so as not to waste precious time fooling with old stuff that may not fire off.
This applies to where your life jackets are stowed, and remember self inflatable jackets have a life as well.
The trick is trying to buy the freshest you can, sometimes they are 6months old already on the marina shelf.....be proactive and buy before expiry date if possible.
Users browsing this forum: Google [Bot] and 19 guests
