Carver C37 odor??
- GRbay37
- Vessel Info: C37 2018
Carver C37 odor??
We recently purchased a 2018 c37 and within the first few weeks have had an intermittent odor that we can’t figure out?? The boat will have no odor then if we empty the waste tank or after being out on the water all day, a sewer type smell will fill the inside of the boat?
We have tried flushing a lot of water down the head, using odor control liquid and tabs, and airing the cabin out with all windows open. It will go away eventually but then come back?
Any tips would be greatly appreciated!
- Been thanked: 1111 times
Re: Carver C37 odor??
- GRbay37
I did a google search on the model and couldn’t find any filter locations either.
Any fellow carver owners have experience/knowledge on the c37 filter location?
- Has thanked: 602 times
- Been thanked: 1310 times
Actually I was thinking to check the shower sump, they can be a real source of these odors......also check for some fittings leaking on your holding tank , toilet, and sink drains.....especially after being put in service after the winter.....good luck with your search.
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 23 times
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
A filter is not used on many boats and is not required if the tank is properly maintained. It is there in case it gets stinky to hide the odour when flushing until you get to the pump out station.
Monitoring the tank level is very important as if it gets full and you flush it will exit the vent line and destroy the filter if you have one and will even mess up a non filtered line by leaving residue in the line and restricting it.
- GRbay37
I had the holding tank emptied and flushed with water. I like the idea of adding water and some Tide, and will do that this weekend!
Lastly, I ran all the water out of the water tank and just bought the big jug of West Marine Water Tank Flush Cleaner:
https://www.westmarine.com/buy/west-mar ... ecordNum=3
Will add this and flush 1-2 full tanks of water through the system this weekend.
Hopefully all of this will get rid of it!
GRbay37 wrote:Source of the post I do think part of it is the shower sump and I flushed a lot of water as well as OdorEliminator through the shower drain.
Nothing beats a good hand cleaning, I have never found any quick remedies that actually beat taking the cover off and cleaning.....
- GRbay37
bud37 wrote:GRbay37 wrote:Source of the post I do think part of it is the shower sump and I flushed a lot of water as well as OdorEliminator through the shower drain.
What is your recommended best way to clean it? Just unscrew the clear plastic top cover and wipe it out with a gentle cleaner? Anything else to take apart?
Users browsing this forum: sbb2112 and 36 guests
