Windlass power issues
- tgebler
- Vessel Info: 2000 396 AC
- Has thanked: 5 times
- Been thanked: 29 times
I replaced the solenoid pack at the recommendation of a Maxwell rep. The problem still exists. Any thoughts on a cause of this problem and/or a solution?
I have asked an electrician to take a look but he has not yet been able to get to the boat.
Thanks.
- Rocketman
- Vessel Info: 2009 44 Sojourn w/ Volvo Diesel D6-500 engines and IPS drive system.
- Been thanked: 24 times
Re: Windlass power issues
Then verify you have no corroded connections.
When operated did you check the voltage at the motor to ensure you are getting proper voltage when engaged?
A windlass should be serviced every so often however this does require removing the motor/gear box. Seals, bearings and oil should be replaced every 10 years or so or at least this is what I consider to be a good interval for my usage.
- Been thanked: 1111 times
If the motor is actually stalling, then I'd check all the connections for corrosion and tightness. After using the winch, you can also just check the temperature of each connection (don't forget the fuse or circuit breaker connections) and see if any are warm or hot... but be careful if you're doing this by hand because one might be VERY HOT. If you find any warm or hot, then concentrate there on finding out why... are they corroded in some manner? (could be inside the shrink too).
Users browsing this forum: No registered users and 40 guests
