over heat
- tjh408
- Vessel Info: 2003 Carver 360 Sport Sedan
- Has thanked: 18 times
- Been thanked: 9 times
Re: over heat
- tjh408
Re: over heat
Good luck
- Been thanked: 1111 times
Re: over heat
tjh408 wrote:Source of the post I had a similar problem with the same motor on our 2003, 360 SS. After changing impellers multiple times thinking I did something wrong, I even changed the housing. I finally had a dealer suggest changing the whole pump. That solved my problem.
Good luck
Just curious if someone actually inspected the old pump to determine what actually was failing. They're pretty simple, so it could only be a handful of things.... like a broken shaft, a faulty mechanical seal, a cam problem or a housing crack are the only things I can think of offhand.
Re: over heat
- Has thanked: 602 times
- Been thanked: 1310 times
Re: over heat
Re: over heat
Midnightsun wrote:Source of the post Simply wear on the housing or the front or back plate will cause leakage, these do not last forever.
Plastic ones maybe. You should be able to get 3000 hrs on a bronze one.
Re: over heat
All depends on your water conditions. Silt and sand will wear anything out in no time.
Put these on a previous boat as the Mercruiser stuff was questionable. Lasted about 1000, hours and they both bit the bullet. Can't get much tougher than these. https://www.hardin-marine.com/p-15774-s ... 2-mag.aspx
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: over heat
- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
Re: over heat
I know it's an effort but just changing a pump on a hunch is also not so great for future traveling on open water. Consider it elbow grease investment into off shore confidence.
(or whatever excuse you can think of to do the job of (dis)mounting the pump twice
- pepmyster
8.1 Volvo Penta
Re: over heat
