Cylinder Head Replacement
- jsurfwhite
- Vessel Info: 2000 Carver 356 Aft Deck
- Has thanked: 12 times
- Been thanked: 4 times
Thanks,
Jim White
Owner Suture Self IV
2000 Carver 356 Aft Cabin
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Cylinder Head Replacement
- Been thanked: 601 times
But in my 40 years of wrenching on cars, trucks and boats, very rarely do heads need "rebuilt". If you rebuild the engine, you of course want to redo the heads, but unless you burnt or bent a valve the heads are usually ok other than oil seals. It seems to me inexperienced marine mechanics often say the heads need redone, and then the problem still isn't corrected. If you burnt or bent a valve, usually its was caused by a worn cam issue or water intrusion through bad manifolds, so that need to be addressed or you will be back to where you are now a bit to soon.
What was the problem that led to the head(s) needing rebuilt?
If you are down that path, as Bud mentioned, any local engine shop should be able to redo the heads for a gm 454 pretty quickly.
Best of luck to you, hopefully you are up and running soon!
- Has thanked: 469 times
- Been thanked: 1765 times
- jsurfwhite
- jsurfwhite
- jsurfwhite
