Slip-In Silencer
- Hudsteve
- Vessel Info: 32 Carver Montego 454 Michigan city Indiana
Slip-In Silencer
Or any better ideas to help quiet our crusader 454's?
thanks
Steve 1990 carver montego
- Has thanked: 78 times
- Been thanked: 1093 times
Re: Slip-In Silencer
A LONG time ago I tried some things called "dappers". They were a 4" tube with some baffles inside. I put them in the 4" exhaust hose headed out to the transom. It was tough to do a before/after comparison because I did it over the winter. Anybody who had taken a trip the prior year couldn't tell that it was any quieter with them on. I ended up removing them and didn't notice an increase in sound either. This is on 350HP 7.4L Crusaders.
One thing I DO think makes a difference (other than, obviously, a real muffler), is to make sure your raw water pumps are flowing all the water they're supposed to flowing. At over 1000 hours on my original pumps, they were still pumping plenty to keep the engines cool, but I ended up rebuilding them as part of PM. The new cams were quite a bit thicker than the old worn cams (I have pics somewhere). The increased flow make a noticeable reduction in engine noise. Not as much as mufflers would, but certainly noticeable.
- Hudsteve
- Has thanked: 469 times
- Been thanked: 1765 times
What kind of muffler do you currently have?
- Hudsteve
https://www.greatlakesskipper.com/maste ... uffler-kit
I will get the exact pic this weekend
what do you recommend?
- vineyardgray
- Captain
- Has thanked: 128 times
- Been thanked: 33 times
- Contact:
1988 Carver
3867 Santego
PCYC
If you have room and cash and really want to get it as quiet as possible, I'd retrofit with Lift mufflers from Centek known as the Vernalift. Here is a common design but there are other base mounted horizontal types... https://www.bing.com/images/search?q=centek+vernalift+lift+muffler&form=HDRSC2&first=1&tsc=ImageHoverTitle
Another option is to contact Hardin and ask them about their exhaust system inserts. These units are installed inside your exhaust hose by the engine but you need a long straight run that will accommodate them. Unless things have changed, they build them based on your application. What you have to be careful with here is that you don't introduce excessive back pressure in the exhaust system.
What is it that is concerning you about the noise? Is it really noisy when you run it at the dock and you're concerned about your neighbours? Are you in an open or covered slip? Sometimes the acoustics at the dock in a covered slip can be amplified by the surrounding structure.
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 23 times
RobGunn wrote:Source of the post I wondering if you simply add a angled elbow at the exhaust exit that would force the exhaust down into the water? Let he water muffle the sound?
I have seen boats do that, and I considered it myself on the 3607. If you do though, make SURE you provide a small relief port so that air can get in and water doesn't get sucked up into the exhaust when it cools down. This solution would work great around the dock and at no-wake speeds, but would do little up on plane unless you extend them further down below the hull. That could be a lot more work though, as the drag would be substantial.
- Has thanked: 598 times
- Been thanked: 1281 times
http://www.google.com/patents/US3291252
Users browsing this forum: No registered users and 43 guests
