Help sorting Riviera plumbing issues 2
- SunsetSteve
- Vessel Info: 83 Carver Riviera 28
76 Albin 25 (outgoing) - Location: Gananoque
- Has thanked: 30 times
- Been thanked: 19 times
- Has thanked: 602 times
- Been thanked: 1310 times
Re: Help sorting Riviera plumbing issues 2
- SunsetSteve
By the way, I could be wrong but that looks like a household water heater so I hope it's not in the engine compartment, it's not fastened down properly because there's usually no fastening brackets on household units, and the wiring looks like it's solid house wiring as well which is a no no. This should have shown up in the survey if you had one done.
- SunsetSteve
I did go to Home Depot and picked up a brass valve to replace - it all seems relatively straightfoward now that I know what it is - so thanks guys.
Now free to focus on the windlass installation.
- Been thanked: 1111 times
And also, one a boat, brass valves aren't really your friend. That might work for the water heater application, but you should avoid brass and prefer bronze valves and fittings.
- SunsetSteve
BTW - the tank is located below the aft bunk, not in the engine room. Possibly a fire might be extinguished by melting the nearby black water tank?
SunsetSteve wrote:Source of the post
I'm not sure which would be worse... an unchecked fire on a boat, or a melted black water tank???
