Belt replacement
Ctmangrum
Vessel Info: 1977 Carver Mariner 2896
Has thanked: 37 times
Belt replacement
Postby Ctmangrum » July 10th, 2022, 12:32 am
So I may not using the search option correctly, but im sure somewhere on here is a tutorial on how to change the belt on a 1976 Ford 351M engine.
Has thanked: 598 times
Been thanked: 1281 times
Re: Belt replacement
Postby bud37 » July 10th, 2022, 5:27 pm
So I am curious.....what belt are you referring to ? Got any pics of this ?
Ctmangrum
Postby Ctmangrum » July 11th, 2022, 4:37 pm
Ill post a pic this week. I want to call it the serpentine but not sure if that's what its called on a marine engine
Has thanked: 78 times
Been thanked: 1093 times
Postby km1125 » July 11th, 2022, 6:18 pm
I'd be surprised if a 1976 motor would have a serpentine belt. Back then they were almost exclusively just V-belts. However, a previous owner could have made modifications to change it over to a serpentine belt system.
Is this for all the accessories on the front (water pump, alternator raw water pump)? Is there only one belt?
Ctmangrum
Postby Ctmangrum » July 12th, 2022, 7:59 pm
Yes. That's why im calling it a serpentine. Looking for any insight.
Been thanked: 601 times
Postby tomschauer » July 12th, 2022, 11:02 pm
As KM mentioned, a 1976 351M would have had a v belt or belts, not a serpentine belt. If you have a serpentine belt, there is a good chance it was repowered with a newer engine, or at least a serpentine belt kit.
The belts, v or serpentine are pretty easy to change. Take a pick of the routing of the belt before removal. Take the belt to an auto parts store and get a replacement and put the new one on.
Netherlands
Phrancus
Has thanked: 16 times
Been thanked: 136 times
Postby Phrancus » July 13th, 2022, 1:31 am
Ctmangrum wrote:Source of the post Ill post a pic this week. I want to call it the serpentine but not sure if that's what its called on a marine engine
that would be a sea serpent.
:captain:
Ctmangrum
Postby Ctmangrum » July 13th, 2022, 7:47 am
So I guess im asking how to get the belt off. On a car, you have the pulley that you can adjust to loosen the belt, take it off, then install the new one. Is there a pulley or flywheel that adjusts for belt removal?
Ctmangrum
Oh, and it has not been repowered
Postby km1125 » July 13th, 2022, 7:49 am
The one thing to figure out on the serpentine belt is whether or not it used a spring tensioner. One of the idler pulleys would be spring-loaded and you can pivot that spring loaded pulley to take tension off the belt, so just having the right tool to take that tension off is all you need.
Some systems will also have a bolt "locking down" that spring-loaded pulley from moving. So, once the "spring-loaded" pulley sets the tension, the bolt locks it in place. Without this bolt, the spring constantly pulls on the belt so any stretch or wear in the belt is compensated. However, with the spring-loaded pulley able to move you can also set up vibrations in the belt which could cause it to come off (which is why some use a bolt to lock down that pulley from moving once tension is set).
Still others use the "old school" way of tensioning the belt with a bolt adjustment. YOU need to set the tension and you normally do that with a tool that clips on the edge of the belt and it indicates how much tension is on the belt itself. This is actually the best way, but also means the belt may need readjustment after stretch or wear. You also set the belt tension for a used belt less than a new belt (because the initial stretch and wear on a new belt happens quickly). The adjustment mechanism can be one of the idler pulleys, or it can be one of the accessories, like the alternator. The last engine I did one of these one, it was the alternator that you used to adjust the belt tension.
