A couple of questions
Jmac
Vessel Info: 2007 Carver 36 SS
Twin Volvo Penta 8.1 GXii-g
7.3 KW Kohler
Has thanked: 20 times
Postby Jmac » July 12th, 2022, 4:52 pm
Does anyone know what the three holes are used for at the back edge of the swim deck (circled in red) ?
(Hopefully the picture is attached).
Also, how or does the shade/screen unlatch from the forward hatch? Mine will not unlatch. The surveyor noted this as a safety concern in case of an emergency egress. (Hopefully a picture is attached for this too).
Thanks in advance for replying.
2007 36 SS
JMac
2007 Carver 36 SS
7.3 KW Kohler
Tellico Lake, Loudon, TN
Has thanked: 598 times
Been thanked: 1281 times
Re: A couple of questions
Postby bud37 » July 12th, 2022, 5:09 pm
No pics yet.......see the add files button just above where it says post reply.......you can preview to check before post as well......
Jmac
7.3 KW Kohler
Postby Jmac » July 13th, 2022, 9:41 am
Swim deck
JMac
2007 Carver 36 SS
7.3 KW Kohler
Jmac
7.3 KW Kohler
Postby Jmac » July 13th, 2022, 9:42 am
Hatch screen
JMac
2007 Carver 36 SS
7.3 KW Kohler
Been thanked: 646 times
Postby g36 » July 13th, 2022, 10:11 am
Sorry don't see pics
Jmac
7.3 KW Kohler
Postby Jmac » July 14th, 2022, 9:13 am
Not sure why 2 pics will not upload.
I'm selecting "add files" and then select the 2 pics I'm trying to upload but I get a yellow triangle ⚠️ symbol each time :banghead:
JMac
2007 Carver 36 SS
7.3 KW Kohler
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 143 times
Been thanked: 134 times
Postby KyleR » July 14th, 2022, 1:09 pm
Maybe pics do not meet upload requirements (e.g. file size too large, format not supported, etc.) and that's what the yellow triangle is indicating?
MV Verity
2002 Carver 396
Jmac
7.3 KW Kohler
Postby Jmac » July 18th, 2022, 6:45 pm
Trying again
JMac
2007 Carver 36 SS
7.3 KW Kohler
Has thanked: 469 times
Been thanked: 1765 times
Postby Viper » July 18th, 2022, 9:11 pm
The shade and screen should separate from each other. Usually it's a magnetic strip along the screen's end and a magnetic strip on the shade's end where the shade and screen meet but different brands might use a different means to latch one to the other when one is moved. You should be able to pull them apart.
The three holes in the platform are scuppers. They could be drains for the lockers in the transom, and if there is a hatch in the platform, that might drain out there as well. The rubber flaps act as check valves that allow water to drain out from a space while preventing water from getting in.
Jmac
7.3 KW Kohler
Postby Jmac » July 19th, 2022, 9:52 am
Thank you Viper for the explanations.
The scuppers makes perfect sense to me now. I was thinking they were places to possibly install a David of sorts.
As far as the screen/shade, I cannot get them to separate. Even the surveyor tried to no avail. I will try to see if there's a part number, brand name, or some other identifier to research how to get them to separate.
Many thanks!
JMac
2007 Carver 36 SS
7.3 KW Kohler
