Low Shore Power Voltage Issue.
Measured voltage at the wires exiting my shore power inlet, 118.9 on both red and black legs to neutral. Measured between both red and black hots and get only 205 volts. Hmmmm.
Theory, they are using a 208v transformer to get dual phases which leave me under powered? Make sense? I do need probably at least 240v into the isolation transformer I believe in order to get proper single phase power on both legs. Any electrical experts out there?
Everything works fine on board with exception to heating elements which are weak. Has probably been this way forever but last week when we had a hard time making toast I investigated a little more to see why.
My shore power panels shows 215volts however not to sure how accurate that is.
Any advice is much appreciated.
- Has thanked: 603 times
Re: Low Shore Power Voltage Issue.
Look at the specs for your isolation transformer. You may have alternate taps on either the primary or secondary side that would allow you to raise or lower the voltage a little bit.
- Helmsman
- Has thanked: 73 times
- Been thanked: 42 times
- Helmsman
Midnightsun wrote:Source of the post Unfortunately my Transformer does not have the boost feature. Oh my, 235lbs!! Looked up to see the cost of a boosted one, Oh My!! $8,000 US but the weight has dropped to 135lbs. Any other options out there?
Charles is out of the marine business from what I understand. There is a type of isolation transformer called a Bridgeport. They sell marine isolation transformers. I don’t know if they do boosting. There is a contact section on their web site. They responded to me within 24 hours. For a 50 amp 240 volt it would take two of their “pucks” to get 12kw output. The price quoted to me was $2,532 and the two units are about 300 lbs total. You may want to send the question to them.
- Helmsman
“At this time, the Bridgeport Magnetics "pucks" DO NOT comply with ABYC requirements for "isolation transformers." The ABYC Electrical PTC and I have been working with the engineers at Bridgeport Magnetics, and I rather suspect that by the 2024 issue of the E-11 Standard, the standard will be revised to accommodate these toroidal pucks. But at that, they will need some engineering assembly/construction/manufacturing changes to do so; so, what is out there today is likely to be obsoleted. Today, they just have loose individual wires emerging from the potting with no strain relief. That will have to change. Furthermore, their design make them highly subject to being installed incorrectly, in places where miscellaneous stored items can be piled on top of them, retaining the heat they produce, and creating fire risk. These toroidal transformers are lighter and smaller than todays isolation transformers, but there are manufacturing concerns with their safety. They clearly have a future in the marine market, but not in their current form factor and packaging.”
Contacted the manufacturer of this unit yesterday and had a discussion. Looks like a solid product and was actually designed to be a drop in product for a similar Charles unit. Not going to do this this season however I will probably get the old transformer out after haul out and start price shopping this winter. Looks to be in the $6500 range.
https://aseapower.com/product/dock-boost-transformer/
Might be easier/cheaper/better to just get a 208-240 transformer and plug between the dock and the boat. You could probably get one for less than $1K and it would always be an asset you could resell when no longer needed.
Just another option.
Hans....does Victron have anything that could help you.....I do like their stuff.....the weight is serious.......mounting would need consideration for sure.........geez my days of moving things like that around are long over...
