Thru-hull plugs that are in the drain gutters
Seif911
Vessel Info: 1977 Carver Mariner 33'
Been thanked: 4 times
Postby Seif911 » May 27th, 2013, 8:03 am
Good Morning All,
I have 4 thru-hull drains that sit in gutters where the water from the cock put is routed. It does not feel like the type that have threads and a nut, but some sort of push in. The are ~3/4" in diameter. And ideas where to buy something like this? All 4 are brittle and falling apart.
Thanks,
Steve
Seif911
Re: Thru-hull plugs that are in the drain gutters
Postby Seif911 » June 3rd, 2013, 10:13 am
Yay, I found some. They are on eBay. They are called 3/4" thru hull white drain tubes. I haven't installed them yet, but they are definitely the right thing.
Thanks,
Steve
Been thanked: 490 times
Postby waybomb » June 3rd, 2013, 1:23 pm
If you can't find it on Ebay - it can't be found!
Users browsing this forum: Google [Bot] and 68 guests
