Riviera Exhaust
- Petemait
- Vessel Info: 1983 Carver Riviera
- Has thanked: 56 times
- Been thanked: 18 times
Riviera Exhaust
We are gearing up for vacation on our newly repaired Riviera. It is an '83 with a single screw 454 crusader.
The problem is, most of the time when under way, we get high carbon monoxide readings in the aft cabin. We are trying to figure out how to remedy the issue, i.e. opening or closing different windows to try and get air flow through there to consistently get fresh air in there.
Has anybody had similar issues and been able to come up with a good solution?
Thank you in advance.
One more thing to throw out there... I still have issues with the engine at idle, usually after cruising, then coming down in speed to idle speed with the engine stalling. Think it's to do with the carb...I have limited carburetor experience. Was wondering if someone could lend advice on tuning the carb. Its a 4 barrel rochester carb.
Again, thank you and best.
Pete
1983 Riviera 2807
Boston, MA
Re: Riviera Exhaust
Petemait wrote:Source of the post ....
Pete
Do you still have mechanical advance distributors?? If so, check to make sure that advance mechanism is FREELY moving. You can take the cap off and turn the rotor. It should move easily in one direction against a spring, and snap back. If it's sticky at all, it may stay in the advanced state when down at idle, which is too much for the engine. Once the engine dies and it gets back to base timing, the engine will run fine again until it gets to high RPMs and advances the ignition.
- Been thanked: 491 times
Re: Riviera Exhaust
Over charging batteries will give off had that can cause the co detector to go off.
The charger on my 2807 went bananas and was overcharging them, and the co detector lit up
- Petemait
Re: Riviera Exhaust
Waybomb, thanks for the reply. The boat does not have a battery charger and i havent had issues with the batteries. It's definitely the exhaust circulating/making its way back into the cabin.
1983 Riviera 2807
Boston, MA
- Has thanked: 603 times
Re: Riviera Exhaust
If you can create higher pressure inside that aft area with venting that picks up clean air from forward it will help, even on deck there can be a problem, get some CO monitors and place around, they can show maximum peak readings over time, will give you a better idea of the scope of the problem. The canvas design can also create a backdraft effect.
- Petemait
Re: Riviera Exhaust
We have CO monitors but we are not letting the kids go back there when we run the boat. This is tough because that is where they like to play. Maybe i will look into some sort of scoop on one side of the aft cabins on the windows?
Thanks again.
1983 Riviera 2807
Boston, MA
Re: Riviera Exhaust
Petemait wrote:Source of the post .... Maybe i will look into some sort of scoop on one side of the aft cabins on the windows? ...
That sounds like a nice plan. BUT, if you do this, keep an eye on the hull splashes and which way the wind is blowing. I've run with those rear hatches open and not had issues, but I've also run where the wind was blowing strong "abeam" and all those windows (and everything below them) got soaked on that trip.
Do you have a forward hatch above the cabin area? On mine I did and you could open that up and it would "scoop" air into the boat as we were cruising. You'd get a really nice breeze into the cabin. Not sure if that would totally solve the aft cabin CO issue, but it might help.
Re: Riviera Exhaust
If you decide on the elbow thing make sure to add some muskrat guards while you are at it.. I made elbows from aluminium dryer duct 90's, the right size to fit the exhaust thru hull fittings....fabbed up the angles needed , locked in place then wrapped the fitting with roving soaked in resin, then painted black....was nice and light at the end.....can be made from many things but that worked for me.
Good luck with your boat and stay safe.
- Petemait
Re: Riviera Exhaust
KM... Checked out the distributor yesterday with a friend who is good with that stuff and it was exactly as you said. We adjusted the springs and played around with it and the boat is running MUCH better now. He suggested i get a new distributor sometime this season because it has some worn parts but in the mean time we are in much better shape.
Thanks again,
1983 Riviera 2807
Boston, MA
Re: Riviera Exhaust
