Impellor replacement on 456 port engine
Bakoboat
Vessel Info: 456 carver 2000
Postby Bakoboat » August 12th, 2022, 8:31 am
Does anyone know the best way to access impellor on port engine (cummins 450 diamond series). (456 motor yacht). Starboard is easy and very accessible but port is away from walkway between engines. Thinking of removing cover off belt and accessing from front of engine.
Re: Impellor replacement on 456 port engine
Postby km1125 » August 12th, 2022, 8:43 am
Can't answer your access question, but I have a question for you. Do your impellers have the threaded insert? What model impellers are they?
mjmason1
Vessel Info: 1999 Carver Voyager 530
Has thanked: 2 times
Been thanked: 19 times
Postby mjmason1 » September 15th, 2022, 10:16 pm
I found it easier to remove the water pump from the port side then work on the impellor between the engines. I bought a couple of bolts to remove the impellors.
