VDO Gauges
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
VDO Gauges
Oil Pressure gauge I found. Seems like same as I have.
https://www.ebay.com/itm/264635865620?e ... SwxsNf7DUz
Temp gauge all I could find
https://www.ebay.com/itm/124143263613?h ... Sw4gZeikpy
- theorifice
- Vessel Info: 1987 Carver Santego 30
- Has thanked: 16 times
- Been thanked: 4 times
Re: VDO Gauges
I have a similar issue with the oil and temp gauges on the port engine.
- tonyiiiafl
Re: VDO Gauges
Re: VDO Gauges
https://fariabeede.com/2-pages/troubleshooting_help.php
At the bottom you'll see what the resistance values should be for a given pressure, temp, and level readings. If you don't get those readings, you either have the European standard units or faulty senders. Check VDO's website, they may have a similar page.
If the readings go to normal after tapping the gauge then it's likely just a gauge issue. Internal connections can loosen and corrode.
