15mm pex
Been thanked: 1310 times
15mm pex
Postby bud37 » August 26th, 2019, 8:51 pm
Has anyone had the push fit- fittings break down over time ?
Bentone23
454 xli TBI Crusaders
Has thanked: 57 times
Been thanked: 5 times
Re: 15mm pex
Postby Bentone23 » August 13th, 2022, 9:28 pm
My 355 is an 86 model. Just replaced a section of line that was leaking. The push fittings were easy to release and reinstall line.
Bruce Bennett
Bentone23@sbcglobal.net
1996 355 Aft Cabin
Central California
Boating on the Delta and SF Bay
Re: 15mm pex
Postby Midnightsun » August 14th, 2022, 6:04 am
Never seen that happen. How old are the fittings that seem to be breaking down?
Re: 15mm pex
Postby Viper » August 14th, 2022, 12:09 pm
This is an old thread but in my experience, usually the fittings that leak are the ones that get removed and put back on periodically like for winterizing a hot water heater with no by-pass. Even under those circumstances, it's usually the line that gets worn at the area where the fitting grips. Constant re and re roughens up that area where the fitting's seal needs to do its thing resulting in a leak. Cutting off 1/2" of line is enough to solve that problem. Any strain on the line from improper hook ups or tight radiuses will also cause leaks at the fittings too.
Re: 15mm pex
Postby bud37 » August 14th, 2022, 12:47 pm
Midnightsun wrote:Source of the post Never seen that happen. How old are the fittings that seem to be breaking down?
2001........plastic became brittle on hot water side elbows, perhaps defective....there was no response back in 2019.
