ignition alarm beeping when turn key on
- rv53
- Vessel Info: 1995 Carver Mariner 330
Re: ignition alarm beeping when turn key on
Mine was a 1993 but I believe they incorporated timers later on to eliminate the annoying beep.
- rv53
- Has thanked: 603 times
rv53 wrote:Source of the post The alarm used to be steady until I started the engine. Now it is a rapid beeping. Unusual. Just port side engine. Starboard still steady beep. Maybe nothing to worry about. Gauges all good.
What make engines do you have ? Count the beeps and note the pattern, does it sound after the engine starts and is running, does it do this every time even after a trip with a short stop ?
As with a lot of these issues a quick check and cleaning of grounds and check connectors for corrosion and loose is usually the first shot in the dark...
- rv53
- Been thanked: 654 times
- rv53
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Users browsing this forum: Carverlvr2 and 26 guests
