ignition alarm
rv53
Vessel Info: 1995 Carver Mariner 330
ignition alarm
Postby rv53 » August 17th, 2022, 7:36 pm
Hi all, Anyone know what the alarm system protects or what sensors are on a 1995 mariner 330 as far as engine goes? Thanks in advance for any replies.
Has thanked: 78 times
Been thanked: 1093 times
Re: ignition alarm
Postby km1125 » August 18th, 2022, 9:10 am
Would probably help to list the engines make/model on the boat, as others might have the same engine but don't know what would have come on that particular boat.
rv53
Re: ignition alarm
Postby rv53 » August 18th, 2022, 10:36 am
The engines are 5.7l crusaders. I would guess it monitors low oil pressure and high water temp but was wondering if it would monitor low water flow through the exhaust or low tranny fluid too.
Been thanked: 646 times
Re: ignition alarm
Postby g36 » August 18th, 2022, 2:09 pm
I would venture as to not monitoring exhaust water flow/temp but that is a very easy add on. I've set mine up on my nmea network with temp sensors and alarm points or could be a stand alone alarm.
Been thanked: 601 times
Re: ignition alarm
Postby tomschauer » August 21st, 2022, 10:09 pm
Low oil pressure, high engine temp and high transmission temp.
Users browsing this forum: Google Adsense [Bot] and 28 guests
