Flashing Anti Bug Anchor Light
Even though I am usually anchored very close to shore and out of the way of any traffic, I would prefer to have something saying I am there. I realize this is not technically legal but definitely better than no light at all. Personally I do believe a flashing light is more visible than a steady one.
My plan is to add and adjustable flasher module to the light circuit right behind the dash at the switch wiring. The module would allow me to adjust the time on and time off of the light. Something like 5 seconds on and then 10 seconds off however would need to experiment to see what works best for visibility and no bugs. I guess i could put in a 3-way anchor light switch which allows me to choose either standard non flashing or flashing. Do not even know if this will work for not attracting bugs but assume it will be better than a light on all the time.
Here is the module I found. https://czh-labs.com/products/dc-45-30v ... her-module
Re: Flashing Anti Bug Anchor Light
Finally found an advantage to having a sailboat, light is 30'+ in the air.
Midnightsun wrote:Source of the post Color temp won't work. This has been an issue forever on all my past boats, even those that had incandescent bulbs which are around 2700k. Thanks for the suggestion though.
There's actually nothing in the rules (that I know of anyway) that prevents YOU from mounting yours at 30ft !!
and, color temp won't solve it, but it will make it better. Stick a blue light on your boat to see how bad it could really be!
- Has thanked: 603 times
+1. Best time to mop her down.
Han's, have you also thought of an automatic dusk to dawn photo switch? Not for the bugs but to switch the light off automatically at first daylight. I installed one on a previous boat and am thinking of doing that for this one too. I'm an early bird but not that early and I'm all about power conservation when on the hook.
