Changing points in 1976 mercruiser 233
- Ctmangrum
- Vessel Info: 1977 Carver Mariner 2896
- Has thanked: 37 times
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: Changing points in 1976 mercruiser 233
- Ctmangrum
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 23 times
- Been thanked: 1111 times
The gap is easy to set and if done right then the dwell falls in line. Always good if you can check the dwell with a meter because that pretty much validates that the point gap was set correctly. The points can be set too wide and that will lower the dwell which is the time that the coil gets to recharge before the next firing. Just about any dwell will work at low RPMs but won't give enough charge time at high RPMs which will reduce the spark strength.
But, I agree with above if you can convert to electronic then do it. 30 years ago there was more of a concern about the reliability of those modules, but those concerns have long since vanished.
- Ctmangrum
Ctmangrum wrote:Source of the post Ill consider it. Will I also have to adjust the timing after changing the points?
Yes, absolutely.
Even a very SMALL change to the gap on the points will vary the timing several degrees. That's also another advantage of going electronic, is that once the timing is set it will stay where you put it (aside from changes in the mechanical advance, which should always be checked and maintained).
- Has thanked: 602 times
- Been thanked: 1310 times
Ctmangrum wrote:Source of the post Can someone direct me to a post describing how to change and adjust points? Im sure it's here somewhere but can't find it. Thanks.
What is your budget here ?.......if it were me in your position, there would be a new electronic marine distributor system going in, especially if you are not familiar with points distributors.....but it is easy to spend your boat bucks......
Just to add, points are cheap and really work just fine if properly adjusted, the issue will be, the distributor is old ( if original ) and is it still a useable item....bushings, advance mechanism, slides, gear etc.....the only way to check accurately is with a distributor machine and nobody has one any more.....this is how I see it anyhow....
- KandJ72
- Vessel Info: '76 Carver Mariner 3395
Twin 351W Vdrives
Refit in process - Location: Central NY
- Has thanked: 20 times
- Been thanked: 3 times
