Quick Tip: Cleaning a Crusader 6.0 Heat Exchanger
- Delorean6855
- Vessel Info: 2004 Mariner Three Sixty, Crusader 6.0s w/225 hours, Koehler 7_3e genset
- Been thanked: 5 times
My port engine was running a little hotter (pushing 180 degrees) at 3000 RPMs. Starboard was solid at 170 and change. I had already cleaned the SB heat exchanger so decided to do the port.
You can see there are some blocked tubes at the bottom. I had already started working down from the top using 1/8" brass spindles to break through the crust in the tubes and followed up with a wire brush. Works great. I used a shop vac with a detail attachment to suck out the debris as I went along.
New end cap gaskets with aviation gasket seal after scraping the surfaces and was good to go.
After cleaning, temps solid.
https://www.amazon.com/gp/product/B01022ZE2O/ref=ppx_od_dt_b_asin_title_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B08CBYP1L3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
- KyleR
- Vessel Info: MV Verity
2002 Carver 396
- Has thanked: 153 times
- Been thanked: 138 times
Re: Quick Tip: Cleaning a Crusader 6.0 Heat Exchanger
A correct caliber gun cleaning kit also works great for cleaning tubes - and is a lot cheaper!
2002 Carver 396
- Has thanked: 602 times
- mjk1040
- Been thanked: 248 times
