Gas in Exhaust
- hinzee623
- Vessel Info: 1986 Carver 3607 Aft Cabin
- Has thanked: 5 times
Re: Gas in Exhaust
Its a merc454 340hp engine
- Has thanked: 598 times
- Been thanked: 1281 times
Re: Gas in Exhaust
https://www.carburetor-blog.com/knowled ... eshooting/
- Has thanked: 78 times
- Been thanked: 1093 times
Re: Gas in Exhaust
- hinzee623
Re: Gas in Exhaust
Update: looks like its running really rich. It appears too much fuel is getting into the barrel. So going to do a carb rebuild tomorrow. Hopefully this will do the trick. Stay tuned.
Open to other theories as well. Appreciate the input thus far!
- RobGunn
- Vessel Info: 1990 Carver 3607 Aft Cabin
"FINALLY" - Location: St. Joe MI
- Been thanked: 23 times
Re: Gas in Exhaust
hinzee623 wrote:Source of the post RobGunn - As a follow up question, prior to discovering this issue. Did you notice that particular engine was a little more difficult to start up cold? Like you have to give it a few pumps of the throttle for it to turn over?
For me, my port engine turns over relatively easy, however my starboard (the one in question) it always takes a few tries, and more or less i need to move the throttle as i am turning the key in order for it to catch. So I am now thinking, maybe my fuel pump has been on its way out (unbeknownst to me, until now). I will still test your theory.
I had no issue with stating the engine, just normal 2 pumps and set throttle to around 1/4 and hit the key.
- Been thanked: 601 times
Re: Gas in Exhaust
Not a ping on you, but QJets are a bit finicky when setting fuel levels and such.
- RobGunn
Re: Gas in Exhaust
Engines would start and run as normal before and after the issue.
- RobGunn
Re: Gas in Exhaust
Users browsing this forum: Majestic-12 [Bot], waybomb and 14 guests
