House batteries
- Chona
- Vessel Info: 1988 Carver 3607
- Has thanked: 6 times
House batteries
I have switched back and forth between batteries and set it to the “all” setting and still nothing. I am replacing the one 4d house battery tomorrow. Any suggestions on why fridge acts like it wants to work?
As a side not I read people watching tv and things off of house batteries. Mine power cabin lights water pump and used to be fridge. No plugs no tv obviously no ac. Is this normal ? Thanks for any thoughts.
Re: House batteries
But, getting back to your issue. You didn't say which one is reading 13 and which is reading 9, but I suspect the house bank and the starting battery is what's connected to the 1/2/all switch and that the generator battery is dedicated to the generator and not really involved here. Although, you should check the voltage on that, because you have one charger for all the batteries then your genset battery might not be being charged, along with the house bank.
That brings up a question.... do you have a shore charger and how is it configured.
If the fridge is running directly on the house bank, and if that's the bank that you're measuring 9 volts on, then the fridge will NOT run on that and you could damage the fridge by trying to run it on a very low voltage like that.
- Chona
Re: House batteries
- Been thanked: 654 times
Re: House batteries
