SeaDek, good, bad and ugly
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » September 21st, 2022, 4:35 pm
I just finished the recarpeting project and moved on to the foam flooring (Amazon) for the dinette. Learned a lot.
It cuts easily, get a great straight edge. I used a 1/2” 4’ long of aluminum angle iron.
I ripped the old carpet up and used it as a template. I did leave an extra inch on each edge that I trimmed later.
Measure 6 times, cut once. ya can;t make it bigger, only smaller when you cut
TAKE your time and ensure the lines are lined up! PATIENCE!
The glue that comes on it in plain english S U C K $! I used 3M spray and then graduated to Weldwood contact cements.
I cut the entire piec from the template around the edges. Then placed the access hatch on the foam and cut it.
Take a day and unroll it, put weight on it to get it flat as possible! That makes placing it easier.
Once it is down, it is DOWN! No second chances!
Lately, to hide any sins, I painted teh edges of the hatch with paint the same color of the Seadek! It looks like it is right to the edge!
Attached are a few photos, So, all new carpet and new dinett flooring. NEXT is the Galley! Not sure if I am going to refinish the parquet or use same foam there. We shall see!
Re: SeaDek, good, bad and ugly
Postby g36 » September 21st, 2022, 5:51 pm
Excellent job you should be proud
tonyiiiafl
Postby tonyiiiafl » September 21st, 2022, 6:47 pm
Thank you! I was skeptical if I could do the job I was expecting. Thank you again, it is a different boat now with the new flooring.
KyleR
Vessel Info: MV Verity
2002 Carver 396
Twin Cummins 6BTA 370HP
Has thanked: 153 times
Been thanked: 138 times
Postby KyleR » September 24th, 2022, 12:46 pm
Very impressive! Thanks for sharing!
MV Verity
2002 Carver 396
