Oil extractor
- BRHEAUME
- Vessel Info: 1995 Carver 355
- Has thanked: 11 times
Oil extractor
Re: Oil extractor
https://citimarinestore.com/citiguide/r ... d-to-know/
That being said and oil extractor does work well enough. I have never had an issue with the Pela brand so I would recommend those. Being you have twin engines you want a large capacity one or you will need to empty it after you do 1 engine.
https://ca.binnacle.com/Oil-Extractors- ... _info.html
Re: Oil extractor
https://www.xylem.com/en-us/brands/jabsco/jabsco-products/17850-series-diy-oil-change-system/
They're a little pricier but I find the electric ones way faster than the manual ones and when you do oil changes all day every day for weeks, that's important. I tried a manual one for about a day and gave up on it, too slow. Try to get an electric one with a 5 gallon pail or just remove the one in the kit and replace it with any 5 gallon pail, just remove the lid and put it on a bigger pail. Hook it up to your on-board batteries. Works to extract and refill. For larger engines, put the lid on a pail of fresh oil and reverse the flow to fill the engines.
- Been thanked: 654 times
Re: Oil extractor
Re: Oil extractor
- plittle2005
- Vessel Info: 1992 Carver 350 Aft Cabin
- Has thanked: 16 times
- Been thanked: 37 times
Re: Oil extractor
https://www.harborfreight.com/multi-use ... 63144.html
Its suction tube is 3/8" ID, fits right over the dipstick tube, and pumps into a 5-gal. bucket or other container. Takes 5 minutes per engine, stores in a tiny space. Pumps like a charm!
For $6.99, what's not to like!
Re: Oil extractor
Ended up with a stand-alone 12V pump with clips to go to the battery, and just used old oil 1 gallon (or 5 quart) containers for the old oil. That's worked or many years now.
I do like the reverso systems. If I had two engines and a generator I'd probably invest in one of those, or just create one like it from components. You could drain and refill all three in no time at all and virtually no mess.
- Has thanked: 602 times
Re: Oil extractor
Heh a question........Consider a 15w45 oil ......what temp would the oil pump easier, hot or cold ?
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: Oil extractor
This is the one I still have....
https://a.co/d/j9bnMUD
- Phrancus
- Been thanked: 136 times
- Contact:
Re: Oil extractor
a stand-alone 12v pump (cheap, clamps on the battery) make sure it can handle motoroil (for some reason transmission oil killed the first one I got) not too strong, not too weak.
good hoses. It should go over the pipe, not in it.
big container to hold the old oil. The first time I bought a 20 litres oil cannister (I have 2 x 9,5 litres to change) and since then I know it will fit, has a handle and good caps (filling and air for emptying) I made a small clamp from wire to keep the hose in the cannister, big mess if it flips out.
a funnel that fits snugly to the filling hole, handling so much oil in a heavy cannister and wobbly small funnel is not a good plan.
I tried a manual pump but it was a mess. Container too small so had to empty it - and remove the hoses and mount them again; messy stuff.
plastic former-cat-litter box that happens to fit under the engines plus kitchen towel was the final touch to a clean and stressless oil-change.
nevertheless: next boat: fixed apparel to do this stuff, diesel filter changes and winterization.
