1994 7.4 390CPMY Mercruiser risers
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
I looked at the past repair order and the repair mechanic just said "2 risers" no part numbers!
SO, any input to dry joint, wet? I know that they can be inspected, but to pull all 4 off, then put them back on if they look OK, just doesn't make sense to me.
- paulr
- Vessel Info: 396 CY Aft Cabin 2001 8.1 Crusaders
- Has thanked: 54 times
- Been thanked: 32 times
Re: 1994 7.4 390CPMY Mercruiser risers
Why risk a 4-$5000 rerpair.
- tonyiiiafl
- Been thanked: 1111 times
- paulr
Period tests over time indicates the rate of ware. When it gets to 30% - 40% of original we change them out.
On a reiser or elbow there is no way to test the interior wall of the elbow that will fail.
The only thing you can do is change them or gambel. I see it everyyear at my marine in NJ
